Drag/Acceleration Weight of the worlds fastest Stinger....
Exactly. IMO the ECU tunes right now aren't providing any sort of tangible advantage over any of the piggyback cars. Sure, Tonka's car is 0.1 seconds faster down the track than a (more or less) comparable car (Kinvara's), but there's no way you'd notice that difference while driving. If we start seeing 120+mph traps consistently from an ECU tune on the same setups then it would be worth it.
There's a [reputable] company local to me starting off with ECU tunes on this platform... I might see if I can volunteer as tribute
Eh, i believe im on par.. please note that i set my PB in one track day with 3 runs on stock tires that have been all but slayed, never got to make more as i never tightened the cold charge to intercooler coupler and it fell off.. Im going to take it out next week on my RX7 FDs tires.. 28lbs a piece on the back 2 tires, 18x10.5 with a +50 offset.. wrapped in R888Rs 265.. I should shave off over 0.2 seconds with the launch ive been practicing and the lighter wheels/better tread... hell i was spinning second gear in an AWD on my stock tires...
Bottom line, im having more faith in JB4 for the short term, but they wont be able to compete once someone fully maps ECU down the road, whenever that may be..
If someone releases an off-the-shelf ECU tune down the road, you may still want to fine tune it based on conditions / mods / etc. I come from the Audi world and it was fairly common to stack an ECU tune and JB4 together
The better flash tuning gets the more useful the JB4 becomes as it turns out. Even Tonka here could use it to fix his top end boost and get MPH up I'm sure. ;)
I'm sure John will sort it out in my next update. I can see Tork tunes taking the top 3 spots in the near future....
errrrr. sounds like ill have my car back tonight with my full exhaust now so goodluck beating a (hopeful) 11.7 ;)
Good luck! 11.7s seem possible with some good cool temps.
Full exhaust meaning new primaries or is the exhaust still primary catback?
I'm sure he will eventually. But then what happens when the weather changes and your load targets change dramatically? Or when E85 mixture or octane changes? Being able to make minor adjustments on the fly can be the difference between a new record and a waste of a day.
I had the fastest Stinger at 28 degrees, through 75 degrees, E0, E15, E20 E25. It's all ready fast all the time.
11.7 is possible at hot temps lol....
I just got out of the training chamber....
Remember me?
might wanna post that on the official quarter mile thread.
Maybe you want to do the honors? Since is better than your time? LOL
Doesn't really work and when the battery does run out of juice, every now and again you can't revive it. Can only be charged with a special charger. It's a good race car battery just know what you're signing up for.
Update. Just came back from a 3 week trip, left the car with no maintainer/trickle charger and the car started up no problem, didn't even require to use the jump start option.
Do you have a dashcam recording 24/7?
Nope, that will definitely change things for any battery. Probably best to have a maintainer in this case.
I installed a fused eyelet plug connection (comes with the maintainer) to the battery, so fitting the maintainer when needed is a piece of cake, just pop the boot and plug it in and thats it. I didn't use the maintainer this time just to see if the battery lasts 4-6 weeks as the manufacturer claims on an OEM car without any additions that could drain the battery, lasted 3 weeks and started without any issues, so I am sure the 4-6 weeks is doable.
TM71 Weatherproof Eyelet
What will it take for a 9 second 1/4 mile Stinger? :D
Dropping it from a helicopter at 1320 ft would get it done (+/- 9.04 sec).
Warning: Warranty and/or insurance may not cover this.
Lets get to 10 first. So far the stuffed and larger turbos arn't really dropping the 1/4 ETs.
Will a 3.3L stroker kit help? :D
I don't know a thing about this engine stuff but I am optimistic. :p
