Sounds like a plan, i'd do the same as well. all the best
Just make sure to put the valve at the same location as JUN, the closer to the tip the better because when the valve is closed the pipe will act as a resonator.
I keep on editing and adding things every time I remember something. For the vacuum line, rather than putting the electronic valve in the engine bay in the heat, I actually put it in the back were the battery/methonal are, the valve response is quicker. Only down side is that you have to wire the switch wire all the way to the back.
