kdrab206
I removed the badges from the Stinger this past weekend and wanted to share my techniques. Please note that I take no responsibility for any damage you may do to your car during badge removal.
Preface
Take your time.
Absolutely no heat is needed to remove the badges.
Prep
Start by lightly cleaning the area around the badge and wiping dry with a microfiber towel. Next use painters tape and outline the badge. I was actually able to slide the tape under the badge a little (1/8") to protect the paint. Then spray a little Goo-Gone along the top edge of the badge.
Tools
Get fishing line under the edge of the badge. Once the line is under the badge pull back towards yourself. Slowly work the line back and forth in a sawing motion. The Goo-Gone you sprayed in the first step should act as a lubricant to keep the line from sticking as you work through the adhesive. If the line gets stuck, gently work it back to free it and add more Goo-Gone. Should be able to work your way around the badge to the pins without too much trouble.
Next get your plastic spreaders, insert one on the left, one on the right and one at the top. Get your fishing line under the bottom of the badge and gently pry up until you can get a finger under. Gently push up to release the badge.
Adhesive Removal
Spray the adhesive with Goo-Gone and allow to absorb for a couple minutes. Use a small piece of the blue shop towel to remove the adhesive, a little at a time. Once the adhesive adheres to the towel discard it and use a clean piece.
Took me a couple hours to do the front and rear badges.
Hope that helps you with your installs.
Trevor
Preface
Take your time.
Prep
Tools
- I used 20lb fishing line. Instead of wrapping the fishing line around my fingers I used (2) pieces of 1" dia. dowel, about 4" long. Cut a length of finishing line (arms span), tape the line to the dowel, then wrap over itself a couple times.
- Goo-Gone
- Blue shop towels
- plastic spreaders (3-pack)
Adhesive Removal
Trevor
