That’s unusual. Unless you have a bunch of mods that will add more drastic variations to IAT, boost, etc. acceleration should feel basically the same at all times. Yes, it will perform better during cold weather months, but it shouldn’t really change how it drives week to week or day to day.
Mine always felt consistently strong when I was stock and I’ve driven in 40degrees and 90degrees+ without much change.
When I first added intakes I could feel heatsoak build up pretty quickly and that was the first time I felt a difference in performance. It felt sluggish and the engine would have to work extra hard in hot weather. Since adding the heat shielding it’s basically back to stock consistency and don’t feel performance change much no matter the air temperature.
I’ve asked a few of my local Stingers and nobody said their acceleration changes or feels different day to day. If you have the means it might be worth logging your parameters(boost, IAT, AFR, etc) to see what’s changing enough that you can actually feel a difference in performance. Might be bad gas if not using top quality premium 93, or slightly fouled plugs(carbon buildup) if you baby the car too much. Hope this helps and good luck.
