GenesisG70
1000 Posts Club!
Coccrodille dundee fan
The dislike for the fake hood "vents" rears its head again.
I heard (when I bought my car a year ago) from my salesman that a local Stinger owner had made the hood "vents" into the real thing. But I never learned anything more about it. To me the risk of water getting where it doesn't belong outweighs any perceived advantage of admitting more air to cool the turbos or whatever.
So today I finally fixed the scraped front lower right fascia I damaged when I avoided a dog and ran into a rock . I was quoted over $1000 to fix it ( they were going to remove the bumper etc etc etc ) I thought I could do it myself for the cost of paint , filler , sand paper , totalling about $65 ( $50 was paint alone ) . I masked off the damage and sanded the area with 200 grit to knock down the rough plastic then 320 , 400 , filled the area with Bondo filler , rough sanded with 320 , then wet sanded with 400 , 600, 1000, and finally 2000 . I laid down 2 coats of primer , 3 coats of color and 3 coats of clear coat . . I will let it set up for a day or 2 then , clay bar , wet sand and polish the area . There is one small drip in the Clear which I'll deal with in the fine finshing , but generally , I'm very happy with the results :
Nice job, love your handy work, looking at your pics for where that scrape was located you would never know that area had any damage.So today I finally fixed the scraped front lower right fascia I damaged when I avoided a dog and run into a rock . I was quoted over $1000 to fix it ( they were going to remove the bumper etc etc etc ) I thought I could do it myself for the cost of paint , filler , sand paper , totalling about $65 ( $50 was paint alone ) . I masked off the damage and sanded the area with 200 grit to knock down the rough plastic then 320 , 400 , filled the area with Bondo filler , rough sanded with 320 , then 400 , 600, 1000, and finally 2000 . I laid down 2 coats of primer , 3 coats of color and 3 coats of clear coat . . I will let it set up for a day or 2 then , clay bar , wet sand and polish the area . There is one small drip in the Clear which I'll deal with in the fine finshing , but generally , I'm very happy with the results :
View attachment 25593 View attachment 25594 View attachment 25595 View attachment 25597 View attachment 25597 View attachment 25599
Nice you deserve a bottle of Tequila!So today I finally fixed the scraped front lower right fascia I damaged when I avoided a dog and run into a rock . I was quoted over $1000 to fix it ( they were going to remove the bumper etc etc etc ) I thought I could do it myself for the cost of paint , filler , sand paper , totalling about $65 ( $50 was paint alone ) . I masked off the damage and sanded the area with 200 grit to knock down the rough plastic then 320 , 400 , filled the area with Bondo filler , rough sanded with 320 , then 400 , 600, 1000, and finally 2000 . I laid down 2 coats of primer , 3 coats of color and 3 coats of clear coat . . I will let it set up for a day or 2 then , clay bar , wet sand and polish the area . There is one small drip in the Clear which I'll deal with in the fine finshing , but generally , I'm very happy with the results :
Thanks , its a pretty simple job in a low visabilty section of the car so I'm happy that it turned out so well and saved $1000 ! I also painted my rear diffuser so the paint has served double duty !Nice job, love your handy work, looking at your pics for where that scrape was located you would never know that area had any damage.
That’s exactly the feel I get now, did you do softest settings on the sways.Front and rear Eibach sway bars with Whiteline endlinks. My butt felt a difference pulling out of the parking lot where I had it serviced. I get the perception that the little bumps and things that made a bit of jostle is gone. A flat, straight ride instead. And the flat ride I LOVE on the interstate ramps. I need more miles with this mod, but it's looking to be my favorite for my driving style - on CRAP roads.
Both soft. Endlinks haven't technically been dialed in yet. One tire has some extra inner shoulder wear so going to get her aligned before I do much else.That’s exactly the feel I get now, did you do softest settings on the sways.
Trust me the more miles you do, the more your going to love this upgrade, it just lifts this car to another level IMHO.
Excellent work my friend. Just like owning a boat. Good on ya!View attachment 25599 So today I finally fixed the scraped front lower right fascia I damaged when I avoided a dog and ran into a rock . I was quoted over $1000 to fix it ( they were going to remove the bumper etc etc etc ) I thought I could do it myself for the cost of paint , filler , sand paper , totalling about $65 ( $50 was paint alone ) . I masked off the damage and sanded the area with 200 grit to knock down the rough plastic then 320 , 400 , filled the area with Bondo filler , rough sanded with 320 , then wet sanded with 400 , 600, 1000, and finally 2000 . I laid down 2 coats of primer , 3 coats of color and 3 coats of clear coat . . I will let it set up for a day or 2 then , clay bar , wet sand and polish the area . There is one small drip in the Clear which I'll deal with in the fine finshing , but generally , I'm very happy with the results :
Thanks Bud ! If you ever get some body rash on the Blue Beauty ,I've got the diploma !!Excellent work my friend. Just like owning a boat. Good on ya!![]()
Do you have a steering wheel cover fitted?
Touch Up Paint and accessories | AutomotiveTouchupI have a similar spot. Can you share the paint and clear you used? Worried about matching the red.
Nope. Medium rare for mewell done !!
"BLING!" Going that extreme actually looks really good.View attachment 25638 View attachment 25639 View attachment 25640 View attachment 25644 View attachment 25641 Here some picture of my car:
Rims is:Volk GTF
Front: 8.5Jx19 + 43
Tires:245/40/19 Hankook
Rear: 9.5Jx19 + 49
Tires:275/40/19 Hankook
Front lip: carbon fiber G4 Werkz
Back lip: stingerhaus
Lower spring: Eibach
Rims is:Volk GTF
Front: 8.5Jx19 + 43
Rear: 9.5Jx19 + 49
