I hit the dyno today and here's how we performed:
2019 GT1 RWD
The car went into the facility around 10:30am, and naturally, as the day progressed the temperatures increased.
Ambient Temp: 86 degrees Fahrenheit, roughly 100 in the dyno facility.
Elevation: 305ft
Fuel: 93 octane (Exxon) for maps 0, 1, and 2; ~E30 Map 3 (I did not test the mixture. I added 5 gallons of E85 to about 10.5 gallons of Exxon 93)
AFR: Will seem a little leaner due to using the Dyno's tailpipe sniffer and my exhaust being stock.
Previous "
Mods": ADD W1 Dual Inlet Catch Can
Dyno: Dyno Dynamics (No correction factor was applied)
If you want to correct for your local Dynojet, add about 10-12% to these numbers.
Baseline
343hp
395ft/lb
Baseline AFR
Stillen Intake was installed
356hp
394ft/lb
Stillen Intake AFR
Next up, I had the
HKS M45iL spark plugs installed. JB4 was also installed, OBDII and
fuel wires connected
Stillen +
HKS Plugs (Map0 - deactivated stock map)
358hp
386.2lb/ft
Stillen +
HKS Plugs AFR
OK, now to the fun stuff
Stillen +
HKS Plugs + JB4 Map1
382hp
452ft/lb
Stillen +
HKS Plugs + JB4 Map1 AFR
Stillen +
HKS Plugs + JB4 Map2
379hp
465ft/lb
Stillen +
HKS Plugs + JB4 Map2 AFR
Stillen +
HKS Plugs + JB4 Map3 (~E30)
383hp
482 ft/lb
Stillen +
HKS Plugs + JB4 Map3 (~E30) AFR
