@Terry@BMS
I posted yesterday to have you look over some logs. You may have missed it. It was at the same time as a few others. Can you take a look and let me know how everything looks. Thanks.
My Post was #2633
Map3 looks fine. If you have an issue at part throttle fud.7 will change the pedal to boost relationship to be more linear and may be preferable.
Since more people keep getting the same weird oscillation issues do you think you’ll start working on the EWG control anytime soon? The linear boost helps a little, but know my buddy and many others are looking for a true “fix” to resolve it completely.
I guess the free 12packs didn’t tempt you ;), so what else can we offer to get that project to the top on your to-do list? Bottle of Tito’s? Name your poison?:D
Tried the linear option, I like it better
I turn fuc.7 ON and since then, at low throttle, 2nd gear, there's a stutter. Any relationship?
I switched to the linear option a couple weeks ago and definitely like it better, but, now I'm having a stumble/hiccup in 2nd gear under partial throttle.
Strange question. What's the rough HP/TQ bump from SSR Downpipes, plugs and the JB4 gain me? Trying to out weight me modifying a "KIA" or selling i and going M3 CS.
I know this sounds funny, but I am having a hard time letting my KIA go
If you ran map 2 and that's as high as you went roughly 60-70hp. Ssr claims around 30hp from their downpipes. So, around 100hp. It's hard to say for sure. That would be my best guess.
Close enough! I think another 100HP would really make this Stinger a blast to drive. Just want to maintain reliability
I am pretty sure that the SSR 30hp was on a car with no tune. I think on a car with a tune the gain from SSR downpipes are much less.
Yeah, idk for sure. I was just going by what they claimed.
Are you talking about the oscillations or boost surging some people keep describing? Or did you have that before and used FUD7 to try to lessen the fluctuations, but now you have a different issue?
The JB4 by itself adds about 70whp/103wtq.
And up to 114whp/126wtq with e30 and intakes only! 441whp/518wtq with just two simple bolt-ons(~$600) is very impressive and can only get better with more airflow.:thumbup:
There is an ongoing debate about secondary DPs gains with a chip/tune and dont think it will be another 30whp, but guessing 10-15whp conservatively. We are waiting on a couple people to dyno test them while using a chip/tune and will know more at that point.
Tuned Stingers are already running sub 4sec 0-60 & high 11s in 1/4m which is very similar to the M3 CS, but that car is smaller and over 500lbs lighter. You really cant compare the two, but in straight line performance the Stinger will be similar and for about a 1/3 the price!(M3 CS=$100k+) Save the money and just enjoy beating cars double & triple the price!:cool:
My cars been feeling super sluggish these past couple of days. So I logged it and paid attention to my boost. Looked like the little boost bar didnt even move. I didnt put the pedal all the way down. But usually at this level I get a lot more boost. Any suggestions?
Looks like steady low speeds, rising to a max of around 40 mph, with pedal in the teens and throttle not much higher. Wouldn't expect to see much boost at all?
Not sure why it’s feeling sluggish, maybe bad gas or low octane and the ECU is pulling ignition timing.
However the JB4 doesn’t even start adding boost until about 40-50% pedal input so that log is all stock settings & boost levels. Do a WOT pull from about 20mph to highway speeds so you get a good log to analyze and see what the JB4 is actually doing.:thumbup:
Oscillation I believe. I didn't have any issues until AFTER changing FUD7. Most of the time I drive in "manual" with the paddles but was able to confirm same issue with paddles and full automatic. When going from 1st to 2nd, shifting between 1500 & 2000, partial throttle, just cruising around, there's a split second hesitation, a hiccup, a glitch, stutter, etc, while already in 2nd gear and same partial throttle. This hiccup happens, real quick but noticeable since throttle is cut off for that split second, then everything goes back to normal. Haven't been able to reproduce with a more aggressive throttle input nor during WOT.
I think the main reason why I can't pull the trigger on any tune is the small issues I keep hearing about. It just seems like it's not really worth all the hassle and the thought that something can go wrong or hiccups can happen
Welcome to aftermarket modifications.
Where nothing goes as planned, everyone has a different experience, and no 2 cars are alike.
That is very true. Everybody loved the tune from X company for the 2016+ Optima. I swapped plugs, catch cans and still lost my engine (detonation at partial throttle), it was a nightmare
You're hearing like 0.1% of the users reporting a problem. Do you expect to sees the other 5000 users reporting that all is well? Same goes for other issues people report on the Stinger - sunroof rattles, brake pulsating, etc. I don't have any of those issues.
No, I understand that. Forums generally make the issues seem way more widespread than they actually are. I just happen to always be in that 0.1%
