Connector II is A
How did the rockford sound? Nice and punchy?Yea I guess everything is upside down in SK.
I put aong screw at the top edge of the sub through the carpet into metal frame of the car works well. Personally I would strap it to the back of the back seat with child restraint anchor. It usually sound better firing backwards anyway IMO.It sounds really good. I've only turned the gain up about 40% and the boost about 10% with the bass on the head unit set at -2. It's nice and deep without sounding like the 4 15"s I had in my 1992 Cavalier when I was in high school.
I've got some rattle coming from the license plate so I need to figure out how to eliminate that. I'll probably put some 3M double sided tape under it.
I'm not at all happy with the location though. I have it in a similar location to where you have yours but mine isn't integrated with the car so it looks horrible and if I drive it probably wouldn't make it a mile before falling over.
Firing backwards sound better than sides?I did + to +, - to - .
I also moved the ground wire. I'm using one of the bolts holding the battery down. That allowed me to relocate the speaker so that it sits against the seat. I put a long strip of velcro across the back to hold it into place.
I think it would add a good amount of kick.
I do want to change one piece of information from my previous posts. You will want to tap into the factory subwoofer leads for the high level inputs rather than the front doors. The signal to the doors does have a high pass crossover applied and you miss out on a fair amount of the low end.
Bandpass boxes are hard to tune properly and needs big box, taking up a lot of space. Good for low power amps and subs that are around 100w. Not popular anymore as amplifier and subwoofer are getting so powerful these days that you can just put the sub in a small box and turn the gain up to hit hard. If you like those low end enhancement coming out from the port just turn be bass gain up 6db which is what ports do in bandpass. In simple ported boxes gives you bass gain of about 3bd if I am not wrong.Been a long time since I tackled something like this (20+ years) was thinking of doing a single 12 in a bandpass box, what's every ones opinion on that?
Sorry for the delayed response. This pinout for the HK amp is in this post.Thanks for the tip. Is that shown in your first image of what wires that it and where they are located?
Awesome thanks, is this the best option for adding a mono sub amp or is there a better option with the SPDIF connections and then using something with it to filter out everything but what I want for the subs?Sorry for the delayed response. This pinout for the HK amp is in this post.
Aftermarket Sub Installation Planning / HK Amp Pinout?
On my 2018 US GT2 these are the wire colors I tapped into.
SUB 1 + White
SUB 1 - Brown
SUB 2 + Red
SUB 2 - Blue
Be careful these were on connector 1 which is red. The pinout refers to this connector as "Connector B". It's kind of counter-intuitive.
Best is dependent on how you want to characterize it. Tapping into speaker level inputs is by far the easiest and least expensive.
SPDIF I'm sure is "better" but I don't know how much fidelity you will be loosing or be able to discern in the sub base frequencies. I also have no idea how you would tap into the SPDIF to be able to run the factory amp and a new one. Can you simply wire tap them like you would a speaker wire?
