3.3TT Exhaust Comparison Chart
Karl Davlin
STL Stinger Club
Missouri
I've been looking at the forum for hours. I've put together this incomplete chart comparing exhausts. I realize the loudness of the exhaust is relative and is somewhat based on the individual. However, this should be a good start for someone to hone in on what they would like to have in an exhaust.
For example, I would like the to cruise quietly down the highway (no drone) and yet yield as much power as possible at WOT.
I'm keeping the numbers (1-5) relative to the original exhaust; where 1 is quiet (equal to stock) and 5 if very loud compared to stock.
I'm willing to update this chart if people would like to give feedback. Hopefully, this will help others as well as me.
For the fitment of Borla...it was probably the easiest exhaust I’ve ever had to line up and hang up. I’ve done probably close to 20-30 exhaust changes across many different cars and this was actually enjoyable.
I’ve heard some of the other videos, but I’d say not only does Borla have a louder drone, but it has a louder and deeper sound in general. Enough to piss off my neighbors. I can tell when my wife comes home from a deep hum inside the house. I personally like it, although many others won’t.
For the price...it was impossible for me to not buy.
I like your style Karl!
Here is mine. Not quite as qualitative as yours but has a few different options to look into.
Add another one to the list.
Ultimate Performance LLC. Primary cat replacement, secondary cat delete / downpipe for $1399
Will mate up to an aftermarket cat back.
They posted it on FB, don't see it on their site. No Dyno, slip times or anything like that were posted.
Strange... I'd update this in my original post, but evidently I can't edit it.
I'd love more feedback so that I can fill out this chart better. :)
I like the idea of your chart but it's all subjective. Very few people have heard multiple exhaust systems in person to reliably rate one to another. (videos just don't cut it) So IMO it won't be really useful if someone that really likes their system rates it high where most other people would rate it low.
Now the one way to make it somewhat quantitative would be to have people use a dB meter or the same dB meter app on their phones at different speeds etc. But then there will still be variables outside of your control such as the app calibration for various phones, the road surface, the brand and model of tires that are on the car, windows up/down, grade of the road, other mods on the car such as intakes...
Agreed, that is why I said the ratings are relative... But, it is a start to put it together in one spot. A dB meter would work great if people could do a "before" and "after" on the same car. Then, it wouldn't matter if the same app was used, tires, road, etc. It would indicate a relative increase over stock.
Let me add two:
JunBL GT non-EVC
Cabin loudness @ 0-40: 1.5
Cabin loudness @ 40-60: 2.5
Cabin loudness @ 60+: 3
Drone: Moderate at 1800~2200RPM, can be annoying when cruising
HP gain: 10~15 claimed, but car felt a bit sluggish when cruising. Didn't dyno it.
Fitment: Good
Weight: N/A
Cost: $1100
Thoughts: Loud in the inside, drone is kinda annoying, sounds good outside.
Girlfriend test: Didn't like it
RES titanium EVC (electronic valve)
Cabin loudness @ 0-40: 2
Cabin loudness @ 60+: 2.5
Drone: None at all RPM with open valves, a little bit of a humming sound with closed valve at high RPM
HP gain: N/A, but car feels faster. Didn't dyno it.
Fitment: Good
Weight: muffler only 26lbs, full exhaust 36lbs (vs. 79 stock)
Price: $3600
Thoughts: No drone, wish it was quieter at low RPM and louder at high RPM, sounds less loud than other exhausts inside the cabin because of the absence of drone but is quite loud outside. Sounds different than steel exhausts. Connects to the OBD port, this is the biggest drawback for me as I would like to connect other things through that port.
Girlfriend test: Passed
By the way, regarding stock exhaust weight:
Muffler: 26kg - 57.3lbs
Midpipe: 9.8kg - 21.6lbs
Total: 35.8kg - 78.9lbs
That's inaccurate, unless SK exhaust is different than US. I weighed mine and though I don't recall the exact weight I remember it being in the mid-50lb range as Tonkabob said.
*Edit: Found my old post. I weighed my stock catback in May and it came to 56.8lbs.
3.3TT - Thermal R&D Catback
Does that include the midpipe?
US exhaust is indeed different from the Korean exhaust but I doubt that there is a significant weight difference as it is made of the same steel.
I weighed my catback - stock mufflers and mid pipe with resonators at 56 lbs.
Ok, I will start an investigation!
Either the aftermarket exhaust advertisement is wrong, either we have a heavier stock exhaust.
But I did lift the two exhausts before install to feel the difference and it DID feel as half the weight. (not an acurate measure!)
Yes, I wanted my write-up to be as detailed as possible so I weighed the entire exhaust, that's mid-pipe and two mufflers with their pipes to compare to my new exhaust. The total for all pieces was 56.8lbs.
It's possible the company that created that picture you posted was trying to over-state the weight savings of their exhaust by exaggerating the weight of the stock exhaust.
Ok so I got the stock exhaust in a box but I don't want to open the box so I weighed it as it.
There is nothing inside the box except the exhaust and some bubble paper(?).
Here is the result:
31.1Kg
lets remove 1.1kg for the box and the wrappring and say its 30kg of metal. That's 66lbs, 10lbs heavier than your weighing and 10lbs lighter than the ad.
I will maybe weigh it more accurately some day if I have time to unpack, clean the mess and repack but I strongly doubt that the result will differ a lot.
So maybe the US exhaust IS lighter by 10lbs, afterall?
Here is the result:
31.1Kg
Or the box weighs a little under 10lbs. I suspect the weight of the box is the culprit.
I have mine in the garage but I'm being lazy today.
