Useful Products for your Stinger on eBay and Amazon
Thank you very much, Jong Ki
Translation:
[QUOTE = "Sea Calm, Post: Members of 21582: 1541"] Genuine OEM Side Wing Air Flow Fender Entry Ventilation for 2018 2019 kia stinger | EBay
I am ordering a replacement of the brake vent cover at Snow White Pearl Premium 2.0t Stinger. These are smoked chrome, I think it will look better than the silver colored ones in the car. However, we are not sure how to remove the existing cover. Has anyone made this kind of change already? If so, did you need special skills or tools? It's just trying to take out the old ones to harm my new baby! [/ QUOTE]
I
I Dont think prying it off is the way to remove it , I wanted to cover the skid plates on my X6 with Viny and tried several things to remove them without luck . Then I just asked my BMW service advisor how to remove it and it was simply pulling it forward to release the "snaps .You dont want to risk damaging your car , your dealer will have access to the proper process as will a good autobody shop . Also I was going to suggest painting the vents or wrapping them . The orange Sema car had those pieces wrapped in Carbon Vinyl and it looked good ( if youre going to all the work to remove them , Customize them !!
just my$.02
Thank you westcoastGT! I was not comfortable about using very much force to pull off the brake vent cover. Will try pulling it to the side before resorting to prying. Looks like it might work by opening the front door of the car and then pulling the cover toward the rear.
Already ordered the smoked chrome covers as replacements. Will put them on and then experiment with customizing the originals.
I'm looking for an led reflector insert for the tail lights crawling up the rear fenders. Anybody see that yet?
Just installed this brushed metal finish magnetic phone mount which looks a treat on the matching finish centre console and works very well.
Universal 360 Degree Rotating Phone Holder Car Magnetic Mount Stand Cell Phone | eBay
Just a point to note if you want to wireless charge the device in the car or at home you need to ensure that the adhesive magnet that attaches to the back off the phone or case is not near the area that houses the charging inductor/coil inside this section of the phone as putting a magnet near it would prevent the wireless charging process from working. With a galaxy S8 if you place the magnet in the bottom third area all will work well.
That fits in (appearance-wise) very nicely...
Looks good! I'm afraid blocking a portion of the cup holder's not, though.
I've used both,
Rather than felt
Carbon material is recommended.
Cleaning and management is much easier and better ..
That's what I would think to. Where I am at it's impossible not to track road salt in to the car. Cleaning the salt off the felt seems impossible. I imagine it would be the same with dirty puddle water, mud, etc.
The felt material
It looks good when installed.
But cleaning is very tricky ...
Genuine OEM Side Wing Air Flow Fender Intake Vent Trim For 2018 2019 kia stinger | eBay
I'm thinking about ordering these to replace the brake vent covers on my Snow White Pearl Premium 2.0t Stinger. These are smoked chrome, which I think will look better than the silver-colored ones that are on the vehicle. However, not sure about how to remove the existing covers. Has anyone already made this kind of change-out? If so, was any special technique or tool required? I don't want to try just brute-force yanking the existing ones off if that will damage my new baby!
Video on you tube on replacement of hubs. The guy just used a screw driver. There is a little niche on the hub built for your screw driver. Easy to pry off.
At first, I thought the screws might be used to mount the cover to the side of car. But based on a closer look it does appear that there are snaps that allow it to be installed by pushing the cover into the side of the car. At this point, my main question has to do with how to remove the existing cover so that I can replace it. Anyone have suggestions?
You tube has video on replacing Kia badges with E badges. It’s very good.
Gotta love this...
Gotta love this...
/QUOTE]
:eek::eek::eek:
Home Depot sells 6 foot lengths of foam pipe insulation for $1.92. Can cut 'em to the exact length needed! :)
Good DIY ! did you do it ?? I've got about 6ft in my garage , I'm going to see how it looks !
Thanks !
