That's supposed to be accounted for by boost being load-limited instead of a fixed pressure (so maybe 14psi summer, 12psi winter), but they must not have it dialed in for all conditions.I guess since its getting colder more dense air the turbos can spool up faster since they are small and the wastegate just keeps shut during wot causing overboost
ChatGPT may assume the WGDC numbers are the actual duty cycle, whereas from what I understand it's instead the JB4's adjustment to the ECU's command (so 50 doesn't mean 50% wastegate, it means no adjustment to whatever the car thinks the wastegate should be).It also told me based on wastegate duty cycle that I still have room for the turbos to work better with a slightly higher wastegate ff setting from 45-48 from my previous 40 setting
It might be worth finding the EWG/WGDC writeups on BMS's forum and paste those into ChatGPT to give it more context.
