Nice I saw that they had 20% off which was the best deal I've ever seen the Eibach stuff on for in Canada.
Yes, it was.
BTW, can you recommend any shops for the installation?
Thanks
Yes, it was.That's why I was so tempted to purchase both front and rear bars together, but I think firming up just the rear should suffice like many others said, hopefully. Now, I have to decide whether to have it installed now or wait until next spring since I have winter wheels on.
Thanks
Sorry can't recommend any shops doe install, I'm not from the GTA I'm from the East Coast.
I did rear only on mine at first, if you go rear only with it on firm be careful. This setup makes the car easy to jump into oversteer mode quick.
Should only take an hour, but they’ll charge you for twoDoes anyone who has the rear sway bar installed know how many hours it would take a professional to complete the replacement/installation? I was at a dealer today and they couldn't tell me as they haven't done one yet.
Haha, thanks.Should only take an hour, but they’ll charge you for two
Haha, thanks.
Not necessarily. Mine took less than an hour and a half and they charged me for one hour.Should only take an hour, but they’ll charge you for two
This is helpful. Autocrossing the car I experienced what you mentioned about correcting the rear when it kicks out by planting the gas a bit. I tried to duplicate that in the next 2 runs but my OE tires were too hot and sliding by then.I went with the Eibach rear sway bar, on "soft" setting (for the street). So far, I have not invested time or money in the front sway bar; and truthfully, I don't think of it very much anymore, because to me the ride is fine. I liked the OE ride fine too, but wanted to improve "spirited" cornering handling. The rear sway bar did that enough for this tyro.I doubt that my level of "hooning" is going to require more stiffness than my car already has.
(There's a scene in the new movie, "Ford vs Ferrari" where Carroll Shelby - Matt Damon - yanks his Cobra around a corner, and it "floats" and kicks out in the rear, very noticeably, but he just counter steers, with the gas pedal down (you can tell), and the rear instantly gets back into line: I've experienced that exact thing in my Stinger, even with the Eibach rear sway bar; but with the sway bar upgrade, it takes more "violence" to produce the side step, and recovery is also more assured and instantaneous.)
I have a Mando unit on the way, but before it’s installed, does anyone know if the stock ECS takes over again when the Mando is not activated by the app (connected), including full adaptive capability? In other words, does just the Hardwired installation of the ECS10 disable the stock setup?What I would like to see them do is offer some additional options you can select to change the Stinger's setting to be like that of some of the other vehicles they have listed. Giving an option to choose from G70, G80 Sport or a tighter tune like the i30 N and Veloster N. It's nice having the custom modes but if you could also drop one of those setting into one of those, that would be nice.
Would one have to physically disconnect the box to restore stock settings, or can that be done via the app?With the box, the stock settings are not active. Whatever setting you left it on in the app is what it will be set at each time the car is started.
