Steering wheel bezel swap
Did this swap today, when you install the airbag back (I didn't fully disconnect it, just popped in the stuff to release it but left the wires connected) the horn piece seems more sensitive. Not sure how tight it was before but is it possible it's not fully secured? When I reconnected the battery, the air bag light didn't turn stay on so I'm assuming everything else is fine.
I assume it is fine. I didn't fully disconnect mine either. I am sure once you push on the horn/airbag, it would click back into place. No airbag light is probably a sign everything is good.
Ok.
Honestly, not really sure how tight it was before I started. I definitely feel it may have been a bit tighter than this but it's not like I never touch that area, unless I need to use the horn or for cleaning purposes.
I can get that way...convince myself that I am seeing something because I think I screwed things up. It is probably just as tight as it always has been. I guess if you wanted to you could pop it off and back on again to be sure.
