My PS4's will worn out by the end of the summer. Afterwards, I'll go with a squared 245/35/ZR19 setup to make the car more balanced. My buddy wnet with this exact setup on his '18 BMW 340M xdrive (which have the exact same stock wheels/tires setup as our Stingers) and he absolutely loves it. I drove the car many times both BEFORE and AFTER and it's an improvement. No brainer for me
Just to make sure I have what you're saying correctly, if running a staggered setup I'll want to ensure the circumference of the wheel(including tire) are relatively the same (within 1-3%) correct? Im assuming this is because otherwise the front and rear tires will be spinning at different speeds. Therefore something like a 245/40 up front and a 265/50 in the back would be a no go even if the wheel sizes are both 19" (with different widths)
Correct. Tire Size Calculator - Tire and Wheel Plus Sizing (there are many others) will let you enter a size, and suggest many other sizes with the same diameter that are a good match. So you need to sort of pick one, then look for a matching size in the back. 245/40-18 and 285/35-18 are one good match (within 3.5mm). 245/35-19 and 285/30-19 are an extremely good pair (654.1 mm, 653.6 mm).
Purchased my Stinger yesterday after selling my Evo X, and was always told to never run staggered wheel setups on an AWD car however after viewing the wheel fitment thread I noticed almost no one is running a square setup on their AWD. Is it okay to run a staggered setup on this car? I want to go 9.5 wide on wheels. Is there a fitment issue I'm missing or is it just preference people are going going with wider rear tires/wheels?
