G
		G-191541
I'm waiting to hear back from Quicksilver... I'm not actually certain which piece is out of alignment, but it definitely is. Of course I no longer have any of the shipping boxes...
As soon as I also hear back from them, I will contact you. I will bring my car back in and see what could possibly be out of whack to cause that. I have a feeling that the bend isnt tight enough, thus allowing the muffler assemblies to be further away from each other. I have a solution to that, but it shouldnt need one. When I was running the SSR pipes, it would always rub the crossmember and or underside of the car. I machined my own secondary to downpipe exhaust gasket (1.5 degrees) basically a small wedge
120thou on one side tapering down to 060 on the other. Forcing the secondary pipe downwards when tightened. I will try the same on my rear slip flange and see how far over it will move the tailpipes. If it works, I will send you out some. This will also be a permanent fix if it does work, and or until Quicksilver corrects it. PM me you address and I will ship some out asap. It should be a five minute fix
