ScottM
Do you notice them being quieter at all?
They seem the same to me. BUT...I didn't notice the PS4 to be loud either, at least not compared to what some folks have said here. One thing is for sure, they are softer.
From what I have learned, a misconception on treadwear ratings is that 300 equals 300 equals 300. Apparently the rating is only relative to other tires from the same manufacturer. Conti's 280 is not necessarily equal to Michelin's 280. The Conti 280 may be substantially lower than Michelin's 320, or maybe close, it's a toss up.
A change of tire brand can be many factors such as desired performance characteristics, maximum speed ratings, comfort, etc. There is also the possibility (I don't have evidence, but suspicion) that some tire choices may be based on incentives from tire manufacturers to use their tires on a particular car. From a purchasing standpoint, the tire that meets the fit, form and function and has the best price and is available would likely be the tire of choice. I think for the Michelin Pilot Sport tires, they have quite a reputation behind that name and putting them on a car almost seems like a marketing gimmick at this point (albeit they are great tires).Maybe correct however I assumed the above numbers to be comparable based on the fact Kia shifted from the Continentals to the Michelins for the Stinger this year due to the increased wear of the Continentals.
Side note, I was surprised to see the Stinger GT in the earlier iterations did not get Pilot Sport 4's in every locale, and that some places you'd expect the Michelin, did not get it as standard. You'd think Canada of all places, where we only get AWD, might have been equipped with an all season rather than a full blown summer tire...because we get legit winter.
correctErm.. that is not the correct size either. 255/35, not 55
That's something else I've noticed- the OEM tires tend to have a shorter life than their equivalent market tire. Same situation on my wife's '16 Volvo with Pirelli Scorpions.
only if you like snap oversteerMaybe next time Ps4 on the front and conti's on the back?![]()
Need new tires on my GT2 AWD. Anyone have thoughts on the Pilot Sport A/S 3+ vs the 4 or 4S? I had the A/S 3+ on a Lexus IS350 and they were fine; they also have 50 percent longer warranty (45,000, halved to 22k for split fitment) vs the 4S 30,000 (also halved to 15k). Price is near the same. Live in Florida and don't track or drive it overly aggressive.
I concur.The AS3s are also terrible in snow, these are not conventional "All Seasons" they are 3 seasons + winters that get down to freezing but with clean roads.
Howdy and welcome. Lots of "tire stories" on here. Your tire wear seems excessive if you are accurately describing your driving style. But do you corner "spiritedly"? Because (especially a RWD) the rears will always wear down noticeably quicker than the fronts on a staggered arrangement. But enjoying the handling will definitely increase the more rapid wear in the rear. I got c. 18K miles out of my OE rear Michelin summer tires; and another 4K out of the fronts. After seeing excessive wear to the outer edge of the FL tire (while the center still had 3-5mm of tread left), I decided to increase psi to 40 all around, which means that the tires warm up to the mid 40s psi. This MIGHT increase center tread wear enough to even the wear out across the tread. So, this second set of Michelins are an experiment.I have Hankook Ventus S1 Evo 3 tyres fitted to my Stinger. Original tyres were Continentals and these wore fast. Mind you, had these Hankook tyres fitted January all round and just been back to them for another rear pair this last week. The wear was phenomenal and use the car to commute. Got 13000km from the rear tyres and thought this rather poor. Shop has rechecked and performed another wheel alignment as LHR was rather more worn than RHR while front pair still plenty meaty and in good condition. I drive mainly highway/freeway at 100km/h with a small amount of city work covering 65km each way five days a week. No track work, no drifting, no burnouts...driven in ECO mode most of the time. Tyres are great, grip and handling very good but seem to wear quite fast. I am suspicious that the shop got the initial alignment screwed up as they spent some time with the car after fitting the new rear set. Anyone with similar stories?
Car is RWD GT with staggered 19’s....
