I get your point and agree all mods should be included when quoting “highest trap & quickest 1/4m”. But then why only declare meth for the JB4 Stinger record, but not say the Tork ecu Stinger with FBO for Torks 11.98 run?Tork & anyone running a turbo-back exhaust is conservatively gaining 40-50whp removing all 4 cats. WMI doesn’t add more power, adding more boost/timing does. So it’s not only the JB4 or Tork ecu making the record run it’s all the related mods that actually made it happen and should always be declared.
Also an equivalent JB4 without Bluetooth App like the Tork ecu is $459 & the WMI kit is only $339=$798. That means you can run both for the same cost as just a Tork ecu by itself.
Lastly, please stop making comparisons between WMI and NOS... They are not the same! NOS kits are actually measured in added HP, while WMI simply prevents engine knock which allows for more power to be made. Even though WMI has other advantages(cooling, cleaning, etc) it’s still just a glorified version of octane booster. It’s not a true power adding upgrade like NOS or bolt on mods.
So unfortunately your UncleChip & NOS example makes no sense and is misleading.
Terry ran a 12.4@116 on a bone stock Stinger and dropped to 12.3@117 with just intakes. And agree, all Terry’s 1/4m times have significantly less mods but still achieves record times. If you compare mod for mod the JB4 definitely seems to have the advantage. Terry’s Stinger with FBOs like Torks would make another 40-50whp and easily run mid-high 11s.
I’m sure once Tork get WMI on his he will be running the same mid 11s too.
True but you left out the most important part...AWD! Your 11.95 run was with 1.8 60ft but Terry’s 12.0 was with a 2.0 60ft. To be fair, we all know if Terry ran a 1.8 60ft he’d easily be running 11.8s
