Thanks J North!
I figure that is the only option for me as well. Connect all the positives together to an empty fuse in the box. Then I'm thinking of connecting the grounds of each side together so if you open the front doors, both the front and back light up.....Or did you connect to the individual (4) grounds?
From the pics it looks like a LR is pink, RR blue, LF blue but which ground is RF? If you had any more specifics of the wire colors that would be amazing! Saves a lot of time checking voltages
thanks again!
I went out and bought about 50 feet of 18 gauge (Black) and (Red) wire. I did two positive wires (Red) out of the fuse box. One out and down to the drivers side LED plate and the other under the dash to the passenger side LED plate. DO NOT CONNECT TO THE FUSE BOX UNTILL ALL WIRING IS DONE!!
I removed the plastic on the kick panels on both sides and there were screws that were being used for grounds (black) so I tapped into that.
I didnt do the rear LED's but if you did, then I would run a (Red) wire from the drivers side and passenger side back doors up to the front door and connect into your (Red) cables from the dash. Then run a (Black) cable from the drivers and passenger side back doors up to the front kick panels where you connected your (black) cables.
The rest is easy:
Connect your (Red) wires from the LED's to your (Red) wires from the dash and connect together.
Then connect your (black) wires from the LED's to your (Black) wires from the grounded screws and your done.
Now you can plug your wires into the fuse box. Shut all doors and then when you open each door they all should work.
Let me know if you need anything else. Thanks!
