Peter Biller
- Mar 21, 2018
I've installed the rear bar as is (see post above). Everything went fine. The driver side was a bit of a pain but with a fine tooth ratchet with adjustable head (Amazon: GearWrench 81230F 4 Piece Full Polish Flex Handle Ratchet Set) you'll have enough room to get the forward nut off the bracket.
The adjustable links again were too short, also see above. The bar has enough space however to where a 3/4 inch short link makes no difference.
The results are outstanding! It's a night and day difference. The squishy roll in turns is gone, grip around uneven turns is much improved, turn-in is better and the car feel lighter yet. I really don't know why Kia has not set up the car like this to start with. Straight line comfort might be a bit softer actually as the bars (front and back) freely rotate in their bushings. The stock ones are fixed in the factory bushings and there is some resistance to the bar to rotation once you unlink them, similar to a torsion spring set up. Not sure if that makes a difference in ride quality though....I can't tell.
I'll drive for a while and see how I like things and then possibly switch to the stiffer setting.
A note on the links. The threaded bolt is quite a bit thinner than the stock links and I doubt that they are stronger than the adjustable links. Time will tell...
