I had mine plugged into the USB data port for Android Auto when testing it. After an hour of being in the car, I gained 25% on a Pixel 2 XL. That sounds about right for normal 5V@1A charging.From what I've experienced, plugging the USB cable into any USB outlet in the car provides minimal charging.
Good to hear! Perhaps I've only paid attention during short trips.I had mine plugged into the USB data port for Android Auto when testing it. After an hour of being in the car, I gained 25% on a Pixel 2 XL. That sounds about right for normal 5V@1A charging.
I don’t understand the point of wireless charging if I have to connect via usb to use CarPlay anyway. Any thoughts?
Also, I purchased amazon’s 4 inch usb cord which is the minimum length that will allow my iPhone 6 to be plugged in and fit in the tray. (Diagonal, due to the short cord length)
The ideal cord length appears to be 5 inches, but not sure if 5 inch usb cords exist.
What bothers me about Android Auto (and I assume Apple Carplay is the same way) is that, when I hit the talk button on the steering wheel, Google (Siri?) is engaged, not the car. I can't interface with the car's Nav, for example, via the buttons on the steering wheel. I can only engage whatever's on the phone. Worse yet, I can't answer an incoming call with the button on the steering wheel. I have to bend forward and tap on the screen to take a call.
I was on Android Auto for a couple of weeks. I'm back to bluetooth for the phone for now.
In Canada, Apple CarPlay does take over on the maps unless you use the POI button on the rear view mirror. To work around it, I typically put in my destination first, then plug in my phone to the carplay.
I am able to take calls normally using the steering wheel button when connected to Apple Carplay since it's Siri that's handling the answering of the call.
Anyone have trouble connecting to car play using an iPhone XS. I can connect via Bluetooth to the system but I can’t get apple car play to work I’ve tried new usb cables, resetting my phone, updating my phone, every thing I can think of.
I’ve tried everything. Spent at least a couple hours on the phone with Apple. The ran diagnostics and took screen shots and they’ll get back with me in a couple daysDid you make sure it’s enabled in the car’s head unit? If it is, maybe toggle it off/on again? After that, I’d go so far as to try a system reset.
Any update on this? I am having the same issue with Apple Carplay. It works intermittently, sometimes after driving for an hour itll just connect, sometimes it doesnt work at all.I’ve tried everything. Spent at least a couple hours on the phone with Apple. The ran diagnostics and took screen shots and they’ll get back with me in a couple days
Yes , it was my phone. After several phone calls w Apple they sent me a warranty replacement phone. Works great but in the end I never use it . I just use the Bluetooth connection.Any update on this? I am having the same issue with Apple Carplay. It works intermittently, sometimes after driving for an hour itll just connect, sometimes it doesnt work at all.
Hi...As always, first go to your Google Play to update to the latest version of Android Auto and Google Maps, then launch Android Auto on your phone, click on those 3 horizontal bars for the Settings page, then simply look for and click-on to-activate the Traffic and Satellite boxes..(this will use more data, of course...but is so much more real and a much more useful and enjoyable experience)...Sounds cool. How or where do you set google earth to your street view?
OK, that has to be figured out by now. Anyone?Worse yet, I can't answer an incoming call with the button on the steering wheel. I have to bend forward and tap on the screen to take a call.
my 2021 facelift stinger can answer called with the steering wheel no problems. Odd.OK, that has to be figured out by now. Anyone?
I mean, my 2017 GTI can handle this situation with no problem. This isn't rocket science.
