So it looks like the hoist feet are flat against the pinch weld, rather than straddling either side of it. Are our pinch welds intended to bear the weight of the car?
I thought the reason for the split in stock scissor jacks, and in rubber hockey puck adapters, was to sidestep the weld itself and lift the car from either side of it (ie within the rectangular cutout), to avoid mangling the pinch welds which is a common issue on other cars.
Or is the split in our jack just to locate the weld? (I'm not sure which bottoms out first, the weld at the bottom of the slot, or the sides)
