They just stick on. There's no indentation on the car itself. The body panels are flat.More than likely I would receive a Kia emblem, which I plan to replace with the "E" but they're differently shaped and grooves are different as well, not sure how I'd do this replacement.
You can see what I mean here:Great thanks!
https://stingerforum.org/kia-stinger-magazine/product/kia-stinger-e-badge-hood-emblem/
I'm not sure if those posts will be in the same spot as the KIA badge but they might be. If not, they're easy enough to remove. You can see some similar instructions here.
Do you mean the scriptish looking STINGER text badge? Or the round "E" badge?Thanks a lot, one more question, is that stinger badge the same size as the on the left of the car? Or is that the size of the ones on the showroom models where is it replaces the Kia badge?
It's the large script text that replaces the KIA badge on the Korean model.
Yes, it's 14 inches wide by a little less than 1 inch high...Does anyone know the exact measurements of the rear stinger TEXT badge?
Please post pictures when done. I'm interested in doing the same once I receive my Ceramic Silver GT2. (Been on order since October)Thanks! Just ordered mine and looking to do the hydro dip carbon fiber look!
Thank you for your order, Sheila.Will do!![]()
Thank you for your order, Sheila.You should have it on Tuesday...
