I'm back.
Hi.
First of all, I don't know if the retard angle supported by Jb4 is correct.
Kia-only diagnostics currently do not support knock retard angle.
So I judge only by looking at the current spark angle.
And everyone says Retard 2-3 is fine.
I think more than that is not good.
It is not an accurate judgment.
It depends on what purpose the tuner is setting the ECU for.
Of course, it would be nice if it didn't become a Retard under any circumstances.
Can the car get high power by doing that?
Retard is also a feature meant to be used.
I make good use of the Retard function.
Retard can also be adjusted at will.
If it's a racecar, it's set tight, but the stinger isn't adjusted.
If you have any questions about the log of this article, please contact me directly.
We need to know who ordered the name, so we can analyze the log file to see how that person's car was set up.
That way I can give you an accurate answer.
It may not fit your car well unless you ordered it yourself.
I like the word aggressive.
Even when Lozic ECU first appeared on the forum, it was said that both TCU and ECU are aggressive.
Well. My goal in tuning is to bring everything I can to make the most of it. That is my tuning philosophy.
If you ask me for any inconveniences, I can solve them.
And let me do some comparisons.
This is a comparison of the ignition timing of the genuine Stinger.
The difference between the power of a six-cylinder engine with one or two knock retards and the data with zero knock retard.
When setting with a small amount of knock retard, more knock retard may occur instantaneously in the re-acceleration situation, but it is important that this is within the acceptable range.
The maximum output is 9 horsepower.
The section with the largest difference shows a difference of 25 horsepower.
Even when the retard angle was 0, the boost was higher.
Therefore, you can use it well to get better power.
It doesn't create data roughly. Even when receiving an order form and creating data, I send it over and over again.
Don't worry. Ask me any questions
View attachment 67868View attachment 67869
