MerlintheMad
10000 Posts Club!
Not malicious. Deliberate would be much bigger and higher. Somebody either just barely caught you with the bottom corner of a door, or was walking by carrying something carelessly. Could even be a flipped up rock, since the direction of deepest to shallowest damage is directional.Arghh had the car for two weeks
Down to metal, this is on the passenger side door near the bottom, looks malicious
This is the part I hate about car ownership. Some German fanboy i bet...
How do I fix this.....
I would sand it super patiently with a light grit of wet sandpaper (2000 or even lighter); sand across the scratch, never with it. Then rubbing compound. Finally polishing compound (all movement across the scratch, never with it). That will take out all the clear coat scuffing. Using the smallest of applicators (toothpick is the ubiquitous tool), drop just the right amount of touchup paint to fill the hole. You could put a drop of primer in first, then Red. Only enough to raise to the level of the surrounding paint. You'll still see it, but with good fortune, when you walk up to that side of your car it won't attract your attention. And from five, six feet away, should be almost invisible.
