<div class="bbWrapper"><blockquote data-attributes="member: 1888" data-quote="eflyguy" data-source="post: 109574"
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
<div class="bbCodeBlock-title">
<a href="/goto/post?id=109574"
class="bbCodeBlock-sourceJump"
rel="nofollow"
data-xf-click="attribution"
data-content-selector="#post-109574">eflyguy said:</a>
</div>
<div class="bbCodeBlock-content">
<div class="bbCodeBlock-expandContent js-expandContent ">
Most bolts are coated to prevent corrosion, you have to get thru that to get a good ground.<br />
<br />
So removing a bolt that screws into a metal frame, you'd find a good ground on the threads, but not so much on the area around them or underneath the head of the bolt - which is where any kind of O-connector would make contact.<br />
<br />
Easiest way to resolve is to use a small wire brush or similar attachment on a dremel tool to polish that area around the threads
</div>
<div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div>
</div>
</blockquote>Yes, became obvious after about 15 minutes. Happened to look up whilst performing an upside down reverse pike with twist and saw the metal bracket....problem solved</div>
