EBC Brakes
- Aug 3, 2021
Thank you to those that recommended us above, a guideline to our pad offerings;
Greenstuff - entry level upgrade from OEM, not track capable. Medium/Low dust. Eco-friendly material
Redstuff – Organic blend, lowest dust & kind on rotors, better friction than Green. For higher HP &/or heavier cars (Good for Stinger) Ceramic particle enhanced, NOT ceramic fibres. Long lasting, not track capable
Yellowstuff - Street performance, great friction for spirited driving, works good from cold, works best when hot. Takes longer to bed. Not low dust.
Blue - Hybrid Street & track pad. High friction street pad capable of track days. Works great from cold. Quicker bedding. Not low dust. 0.52mu coefficient
Unfortunately it is nearly impossible to have a high performance pad that is low dust, the nature of 'performance' means a more aggressive pad, and most of the dust from using a high performance pad will be from the rotor itself. Redstuff have good friction whilst being low dust, but are not recommended for track use.
I hope this helps, you can find our full range and online seller through the link in our signature below, with exclusive forum discount FORUM10USER for 10% off
