3.3TT Awd vs rwd motor
Blakeu21
I just got a 2018 gt2 with the 3.3tt and it’s awd. I got the car with a blown motor and I’m now in the market for a motor lol. When I was looking I found that the awd motors are a lot harder to find and cost about 2k more. From my understanding the long blocks are the same. So in that case can I just buy a motor that came out of a rwd and put it in my awd without modifications? Thanks in advance!
Awd and rwd engines are little different. Front axle is going through the engine. Probably upper oil pan. You can probably swap that pan, but I am not sure.
I want to sub to this, so I'll make an uninformed comment while I am at it. Folks pull the fuse to disengage AWD. So, the spinning hardware isn't powered at all, just idling mass.
If this has never caused any reported problem, it stands to reason that if you removed all the bits relating to AWD from the suspension and put a RWD engine in you'd simply have RWD with absolutely no issues.
Yes well research suggest that if you have all of the AWD bits to go on you "should" be able to put the identical 3.3L Stinger engine in from a RWD car.
They talk about the oil pans, the fact that an AWD does not have a mechanical limited slip diff, that there are different mounting brackets and so on with an AWD car but if you have all of these on the original car then you can re use them.
I think you really encounter problems if you try and turn your AWD car into a RWD mechanically then, you are missing a lot of bits.
The extra $2K is there for a reason. Buy that.
Alright this makes sense I am wanting to keep it awd of course. I have the original motor and the car is completely all there just seized.
I guess my biggest question would be would you buy the rwd motor and save the 2k and swap the parts from your old awd motor over? Or would you not take the risk and just get the awd motor
I would pay the $2K extra and get the AWD engine as a direct replacement for what you have.
It's going to bolt straight in and you are going to have a new car again.
I was curious about this and went looking for pictures. I believe this hole on the passenger side of the oil pan is where the front diff mounts:
So I have seen this in my research. I also have access to all data and the part number for the short block is the same. I still need to look at the part numbers for the long block. I have the old upper oil pan from the old motor so I could swap it.
Does anyone have an exploded diagram for the awd motor with part numbers and one for the rwd motor to compare the part numbers and see what differs?
You could start with KiaPartsNow, and filter down to the RWD & AWD 3.3:
You could also look at the complete Stinger Service Manual
This link takes you to the engine.
If you go to the third heading along the top StingerSM it takes you to the complete car.
Both links here
Do yourself a big favor and use the proper stock parts - it will be less headaches and cheaper in the long run.
The hole in the pan is for the axle to pass through. Sure, "it should work" to use a RWD engine from the oil pan up, and use old parts oil pan down.
I went though all of these and compared the part numbers. Everything is the same besides the motor mounts, and upper and lower oil pan. So in theory it should work. It would save about 2k and would come with new turbos.
I definitely am thinking about this the whole time it’s the only reason that I have not already got the rwd motor. But saving the 2k does sound pretty nice.
Sounds to me like you haven't got any money.
That's a bad position to start with.
Most people out there with a German marque spend $2K on a service.
If I could safely say, you have spent more than $2K in people's time and effort in responding.
You have some pretty good advice there. No-one I think is a Kia engineer and performed this work but various people (including me) have looked it up, looked at the differences that are provided with a simple google search of "what is the mechanical difference between a RWD and AWD Stinger?'............... and provided the complete service manual to work through to make an informed decision.
Personally, and for your future owner out there, I would put the direct replacement engine back in and spend $20 a week less for the next two year's to get my $2K back if I was that worried about $2K. I'm not.
Good luck with your decision.
