Ek9max
Out of topic but Sways are better first mod compared to springs. If sways on soft are not good enough then go for spring.
More looking to make the car look better vs handle better personally .
Both on a level but you sure can't deny the aesthetics. Which made for a "fun" conversation with my wife.
Pics?I recently put in Eibach springs and sways. I honestly think it's a better ride than stock, and my roads are pretty shitty - handling is amazing. I also had new wheels and tires put on at the same time as well, so that might be part of the factor as well.
Honey badger don’t give a fark about handling. Dis is about the look bruuh.Out of topic but Sways are better first mod compared to springs. If sways on soft are not good enough then go for spring.
Yeah. Get em jay.More looking to make the car look better vs handle better personally .
AWD, thanks!Looks pretty awesome . Rwd or awd?
What is your wheel and tire setup?
Ark 270's 19x9.5 square - Michelin Pilot Sport 4s "Limited Touch", 255/35/19 square.What is your wheel and tire setup?
Here are the ARK GT-F springs on my car. There is a before and after, you can see it lowers it quite a bit.
Before:
Kia Stinger Ottawa on Instagram: “Before Ark lowering springs, will post the "after" once I pick it up from Kia.”
After:
Kia Stinger Ottawa on Instagram: “Final result!!!”
Oddly yours looks lowered but the blue car at the beginning of the thread looks like the same before and after gap. I wonder if Ark springs provide more drop for AWD (and maybe his is RWD?).
OP, rumor has it Eibach was designed for AWD Stingers so all RWDs will have a bit of reverse rake. Initially I was disappointed that my rear seems to be lower than the front. I thought my installer messed something up. Then I realized all RWD Eibach Stingers look the same. So if a little bit of reverse rake isn't something you want I would steer clear of Eibach.
The gap on both looks much different than the gap on mine... I wonder if they have 18" wheels?
Yes, I know, that's why I liked Ek9max's comment and replied to shrikecorp about handling.
Offsets?Ark 270's 19x9.5 square - Michelin Pilot Sport 4s "Limited Touch", 255/35/19 square.
+25Offsets?
