Can I ask how much the rim and tire setup cost and where you got it? I like the set up, would like it in a lighter color though
We helped out his contact who imported the set to his country. Let me know and I can help you out!
Looks awesome. Best I have seen! RWD or AWDInstalled my wheels yesterday and I am very happy with the fitment. I wanted a little meat on my wheels rather than a thin lip so I went with 255's in the front and 295 in the rear. I took several measurements before buying them and decided to go with an aggressive offset in the rear with 295's and thankfully they fit perfectly, the front's I got +42 but they rubbed on the strut, with a 3mm spacer they cleared but it was too close to be safe, so I ended up with a 5mm spacer. My dealer sourced the wheels/tires from "Get Your Wheels", they did a good job and packaging was great, I recommend buying from them.
ACE Alloy - AFF02 Black Chrome
Front - 20x9 +37 - 255/35/20 - Firehawk Indy 500
Rear - 20x10.5 +50 - 295/30/20 - Firehawk Indy 500
Weight with tires,
Front - OEM 24.6kg - ACE 24.5kg
Rear - OEM 25.7kg - ACE 26.6kg
Car is much more stable and handles better with very minor increase in road noise, ride comfort is almost the same as well.
I got the wheels from GetYourWheels.com, the offset and setup is in my signature. I wouldn't go less than +50 in the back if you are planning on putting 295's and lowering it.
I think 265 on back is max. That's what I have.@white03 - no way on stock wheels.. Stock wheels are 19x8 and 19x8.5. Max sizing on OEM wheels is probably 245 on front, 265 on back, MAYBE 275 on back.
You also went ~2 cm taller tires than stock - would keeping the stock tire height make it easier to fit 295? I'm AWD and 255-35-19 and 295-30-19 is such a nice matching set..
Bahrain Stinger.............
You said you put Firestone Indy Hawk size 255/35/20 and 295/30/20 tires on your new rims.
I like the way they fill the wheel wells and also might like a little more beef to my tires. So at the risk of showing my ignorance about tires and wheels, would these tires fit on OEM 19" rims??
