Volfy
1000 Posts Club!
If you just like the looks of the larger 19" wheels, there is nothing wrong with that. Go for it.
However, if you care at all about ride and handling, 18's have a much wider range of tuning options. If you are buying aftermarket wheels, an 18" wheel will be lighter weight than a 19" wheel of the same width and design. It would also have less rotation inertia, which will accel/decel quicker than a larger hoop. It's pure physics. Stock G70/Stinger 19" rims are very heavy, upwards of 35 lbs/wheel. Going aftermarket, you can easily pick out 18's that are 20 lbs, or less.
The more mass the wheel has, the more it wants to stay exactly where it is/was, when you hit a pothole. Not only is that bad for handling, as the unsprung assembly reacts lazily, it can also be more prone to impact damage. Seems like every winter/spring, there are lots of forum/FB posts of bent, or even cracked, stock 19" wheels. Yes, you can always wrap larger tires with more sidewall height to protect the 19"s, but now you are adding on even more weight and rotational inertia. That's going the wrong way, if you ask me.
Aesthetics are just want a guy is used to and is mostly objective. To me, what works right looks right... not the other way around.
The 3.3T drivers can count on the HP/TQ to overcome the heavy wheel deficit and not notice much difference. GT-Lines cannot. Keep it lightweight so you can maintain momentum and make youself a happier - and better - driver.
