Shockington
- May 1, 2018
NOOOOOOOOOOOO !!!!
Oh....It's going to happen!
The car lovers social network
Automotive components
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
NOOOOOOOOOOOO !!!!
TSK TSK , you'll look like a Mopar ......................send pics , we will want to see , anyone here that can comp it up to see first ??Oh....It's going to happen!
Are the tips just wedged in there or did you attach them to the exhaust?Installed the Akrapovic tips today! Really not much to shave off (top and bottom) of the stock bumper outlets. After install you do not see the shaved areas at all. I used a dremel cutting blade, pushed forward and back to shave the plastic, not cut. The dremel was VERY precise!!! You have to remove the mufflers to remove the OEM stainless tips, then make sure the tips can fit through the exhaust holes correctly, reinstall the mufflers and fit the Akrapovic tips. The look is so much better IMO.
Before
After
Some more shots
View attachment 10576 View attachment 10577
IMHO , the rear "architecture " of the car's design is very organic and really lends itself to the OEM oval shape the square butts of the Mopars , Lexus and BMW's somehow seem to suit the rectangular tailpipes ................looking forward to see it though !!I can't find them anywhere, that's the problem.
I wish the God damn forums would let me post links......
Firmly attatched to the exhaust.Are the tips just wedged in there or did you attach them to the exhaust?
I put it up on ramps. I would not recommend trying the install ground level. You have to remove the mufflers to remove the stock tips.View attachment 10786
Hey there.... did you have to remove the muffler (like Rango) as well or just the existing tips?
How hard is it to remove mufflers? I might do it myself for the gains and sound..
Sorry for the way delayed answer lol.Rango - which spoiler did you put on the back?
Removed the mufflers. Remove 2 bolts from the tips, slide them out. Very little cutting is needed on the top and bottom of the tip holes, maybe 1/8th of an inch or less. After cutting, if you reinstalled the originals, you could not tell that they had been cut.How do you pop the originals out? Any others out there that could fit without any modding or cutting?
Can you show a picture of the exhaust tips attached to the mufflers ?? they looked wedged in...would like to see a pic please...i wonder if there will work with the ssr axle backRemoved the mufflers. Remove 2 bolts from the tips, slide them out. Very little cutting is needed on the top and bottom of the tip holes, maybe 1/8th of an inch or less. After cutting, if you reinstalled the originals, you could not tell that they had been cut.
They are wedged in because I did not want to cut the Stinger's exhaust holes more than necessary, but they are also attached firmly to the muffler tips with compression clamps. You can order these tips in any inlet size on Aliexpress. Mine are 2.5 inch (89mm) to fit the stock exaust. On the SSR muffler delete axlebacks, the pipe ends look much larger than 2.5. Would have to measure and order the correct diameter for the pipes. I'll take some pics for u tomorrow in the daylight.
