Dyno runs stock, jb4, keen deaign, jun bl
jdouga
2018 Kia Stinger on the dyno
Stock 311/356
JunBL Exhaust 321/380
Keendesign Chip 366/428
Burger Motorsports JB1 367/433
WHP/WTQ Keen Chip w/ Stock exhaust 363/426
This guy has once again done us all a solid for helping advance this platform,and here he is giving us nunbers now too, for that thank you sir.
Thanks for posting that. I wonder if he was using map 1 or 2 on the JB4.
At any rate 46 hp and 75 ft lbs is very impressive for a $220 mod.
@Kiacruzer thanks for doing the video man!
At any rate 48 hp and 55 ft lbs is very impressive for a $220 mod.
I already asked, but havent yet received a response, i wonder how much it will improve when and if the canbus is available or if a traditional ecu tune will still be a lot better.
For those that can't watch the video:
JUN BL w/ valves closed (should mimic stock but won't quite be the same as it's more high flowing):
311.4 HP
356 FT-LBS TQ
JUN BL w/ valves open:
321.4 HP
380 FT-LBS TQ
w/ Keen Design Tune:
366.9 HP
428 FT-LBS TQ
w/ JB1 Tune:
367.3 HP
433 FT-LBS TQ
should improve a lot.
Appreciate Kiacruzer's video, but a bit puzzling that he's reading the dyno results while he's driving!
doesnt take much focus away from driving to read a big number on the top right of a page.
Were you running map 1 or 2 on the jb4?
Nit sure if mine is set up like everyone else. I was the first so i dont know what settings he put it under. But it peaked at 17.5psi.
Stock it's set at map 1, which is +3 psi over stock.
If you could do a run in map 2 when you go back that'd be great. I ran 0-60 in 4.30 on map 1 and 4.07 on map 2. I'd love to see what the hp difference between the two are.
Instructions on switching maps?
Are there copies of the dyno charts themselves so we can see where what gains were made, etc.?
Yes. Its in the video. I dont have the time exactly when they go up but i do post all charts. Going back again on monday and doing some more runs before dropping off the car again for a nother few weeks at another shop for stinger development.
