[VENDOR][FS]: Kia Stinger - Eibach Anti-Roll Kits Sway Bars - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is proud to present to the Stinger community:
(BUY NOW)
Description:
The Eibach Front/Rear Sway Bars affect the handling on the lower end of your Kia Stinger suspension
These tie the lower suspension components together across the rear, & help prevent oversteer & understeer
Thicker construction over stock sway bars keeps your Stinger flatter in turns when cornering by decreasing body roll
The Eibach Front/Rear Sway Bars provide better cornering, especially while at high driving speeds
Both Front & Rear Sway bars are a tubular solid construction and have a two-way adjustment
Specifications:
Rear Sway Bar Thickness: 19mm
Front Sway Bar Thickness: 25mm
Includes bushings for installation
Easy to install and are a direct replacement for OEM sway bars
Vehicle Application:
2018-2023 Kia Stinger (All models)
THANK YOU FOR LOOKING!
Would love to hear some reviews on these, folks!
FYI,
Vehicle Applications:
2018 Kia Optima 3.3T
Having mine installed Thursday. I’ll post something once it done.
Can't wait to hear your feedback! :)
FYI,
Oops, thanks for pointing that out. We are getting tons of new products listed on the forum from the website. From time to time there might be errors, so please help us catch them by pointing them our as you see them. Got it fixed in the description! :)
Front bar install should be easy from the underside pics I've seen. It's bolted to the bottom of the subframe and easily accessible. The rear bar looks like it's mounted on the top of the subframe between the body and rear cradle. I question if there is room to get it out without dropping the sub frame.
Got any coupon codes or discount on the sway bars?
Not with Eibach, we have the smallest margin for profit with Eibach & K&N and already have the parts listed cheaper than elsewhere online. Any other product line than OEM, K&N or Eibach, I would be happy to offer you a discount on.
Works on 2022.
There is no need to drop the rear subframe. I had the Eibach rear (and front) bar installed on my 2022 Elite without dropping the subframe. It was VERY tight and the technician was somewhat frustrated tightening the bolts but it got done.
Ready to take your Kia Stinger to the next level without breaking the bank?
We got you covered at the K8 Stinger Store with this Front and Rear Anti-Roll Kit from Eibach.
OEM suspension components from Kia are built as cost-effectively as possible instead of performance focused.
As enthusiasts, we need to push the boundaries and that means it's crucial to pick up one of these Anti-Roll Kits.
Grab yours today or reach out to any member of our team if you have any questions!
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
