2018 battery, surprisingly doing well
Today, I very much expected to have "difficulty" starting... But to my pleasant surprise, It fired right up
Sounds like a little bit of a slow crank to me...but I guess the real question is, what did your voltage return to after some driving?
I'm guessing you don't use or care about Coasting mode (and have ISG disabled)...
I used the alternator to charge the battery for about 2.5 hours, and then 6 hours later it's at 12.51v (The state of charge (SoC) in the image below is merely an estimate based on voltage & a lttle Nernst Equation adjustment for temperature, it's not a real valid SoC).
See the voltage tapering off... It will probably get down to 12.3 in a few days.
I made a homemade module to toggle ISG off - and brake hold on, each drive cycle, several years ago. So my ISG defaults to OFF, and my brake hold defaults to ON
Definitely a slow crank, down to 8.86v
I was surprised it started at all.
Continuing as a 🧟‍♂️ with my battery abuse/neglect...
I just got back from probably my last vacation :confused:
why your last vacation?
Here's the OEM AGM batt in our 2019 base. Starts and holds charge well enough that most owners wouldn't bother to think there is any need to look at replacing. However, my battery analyzer tells a different story - still serviceable but in the twilights of its usable life. I would not take it on long road trip with this battery. However, because this car is now used strictly as a local runabout, I'm letting it stay put but keeping a close eye on it. I'll likely swap it out later this year. Last time I installed a good aftermarket AGM in our old '09 Genesis sedan, it lasted 8+ years. So, realistically, this will be the last time I'll need to renew the battery in this '19, so really no sense waiting till the last minute and putting a strain on the alternator with a weak batt.
Are you able to host that pic elsewhere - imgur? Site refuses to show full version due to my adblock settings.
I'm still on the original battery in the '22 (bought 2021/08). I keep it on the battery tender most times given car isn't driven much (20K in over 4 1/2 years).
It shows an Acclope BT60 Pro hooked up the OEM AGM 800CCA SAE/EN. Screen on the BT60 shows SOH:35% CCA:473A with STD:800A (which I entered per battery label) R:4.72 milliOhms.
It also shows SOC%:0% VOL(TAGE):12.00V, which is not accurate, since I had just recently driven the car on a couple of longish runs that should've charged the batts. That goes to show why you should not rely on in-service (under load) voltage reading. If this was open voltage, then it would at least correlate better with the battery's SOC.
Looks similar to this: Watch Acclope BT60 PRO Test on LIFEO4 Lithium Battery Analysis on Amazon Live
Yeah, I thought they'd sorted out the aggressive scripts & trackers, but the alerts have popped back up for me with a vengeance:
You have 0 clear page views and require a total of 92 clear page views to remove the AdBlocking status.
^ This is with default Brave browser settings, so the scrolling ad bar at the top still runs but the really intrusive scripts are being stopped. I see 30+ third party connection attempts which is crazy...everyone should install a privacy browser (Brave, DuckDuckGo, Opera) at this point.
That scrolling ad thing was making me dizzy. Used Ubo to remove it entirely.
We should probably move this to site discussions..
