Car shaking after hooking up JB4
  • Did you separate the coil packs?
  • Did you remove the intake manifold to to the plugs?
  • Did you torque the spark plugs properly?
  • What did you gap the plugs at?
  • Did you ensure that the connections are plugged in correctly?
  • Did you open the JB4 enclosure? If so, any pinched wires/chipsets or did you get it closed back up nicely?
edit: I see you bought a used one....that adds another layer of questions...
Seems like I’m getting MAP code errors and possibly some sensor is messed up? I’ve check all the connections that the JB4 uses and I don’t know what’s messed up
do these power pack wires look right? Is it possible we didn’t put them back right and switched the wires? That would explain the 2 cylinder misfires
Holy f*ck I think that was the issue.
Yeah. I think you had those two cylinder coil packs swapped.
That's generally why I only do one plug/coil at a time. If you gap your spark plugs before you install the set it doesn't take long.
I doubt you hurt anything either. Lesson learned.
Do y’all recommend taking off the intake manifold or trying to replace the spark plugs without removing it? About to install the HKS spark plugs to get ready for JB4 pro(beta). Thanks
You do not need to remove the manifold, or really anything besides the engine cover and coil packs. My recommendation would be to gather your swivels & extensions and tackle the #3 cylinder first (left center when facing the engine bay) so you know you have the hard one out of the way.
For your first time in there, if you can get to that plug in under a half hour, the other two on that bank a half hour, and the three on the other side in a half hour, you're looking at an under two-hour job even with cleanup and taking your time measuring plug gap.
What swivels do you recommend? I have those swivel spark plug socket. I’m going to do one at a time and I agree to hit the hardest one first.
