Hi everyone
StevenP
Does anyone know if my 20185 Kia Stinger Gt2 speedometer can be adjusted it is off 2 MPH, dealer is stating no?
If not adjustable, can be compensated with different size tires. Mine is off 1-2 mph too.. Reads high compared to several gps's.
Please use a more meaningful title in the future.
Welcome. Moving this into the Stinger forum.
The speedometer is more accurate at surface road speeds. Once up to freeway speeds the c. 2 MPH discrepancy shows up. But that didn't stop the cop from saying last Sunday that my 79 MPH cruise control setting was 79, pushing 80: so, I don't know; you would think that a CC of 79, if c. 2 MPH higher than actual, would show up as 77 pushing 78?
^^if c. ???
What does your gps show when the car's speedo indicates 79? I tested with 2 different garmins to get the 2 mph speed difference. I should try my phone too, it's relatively modern (released Q4 2019) so gps should be reasonably accurate.
If you deviate from stock tire sizes and/or different tires have different diameters even for the same tire size.
Is it off by 2 MPH @80MPH (2.5% error)
Or off by 2 MPH @ 10MPH (20% error)
The USA has a 10% error limit for commercial vehicles, not sure about non -commercial
United States​
Federal standards in the United States allow a maximum 5 mph error at a speed of 50 mph on speedometer readings for commercial vehicles. Aftermarket modifications, such as different tire and wheel sizes or different differential gearing, can cause speedometer inaccuracy.
^^if c. ???
"c." means about or approximately.
I've never messed with GPS. Luddite, or borderline, here. Hah. :P
Currently on Nitto Motivo UHP A/S, and I have no idea if there is variance in OD with the Michelin PS4S (which I assume is identical OD with the PS4 that was the OE tire). Maybe the cop's speedometer is spot on and my car doesn't have a 2 MPH discrepancy.
I am trying to find out my HP and Torque for my GT2 with Typhoon Cold Air/ Level 5 Chip/Isky-Kia racing cams/Amsoil Racing 5-30/Active Spoiler and Dam/y racing tires/Gloss it ceramic application
Those Dam/y racing tires/Gloss it ceramic application probably add a good 50HP without questing
Are you high? I don't understand a word of that.
That's my point....
It's a word for word quote of the guy before me....
@StevenP what are these things?
  • Dam/y racing tires
  • Gloss it ceramic application
That's my point....
Lol. This is not a slow day. And I am not keeping up. Ha hah.
