Volfy
1000 Posts Club!
As much as I'd like to believe what you said, the reality is, unfortunately, more nuanced than a simple "JB4 Performance Tune will NOT void your warranty."The JB4 Performance Tune will NOT void your warranty with your dealership or with Kia, as that is not how the warranty works.
Please take a moment to read the following information on our website, which will give you a better idea.
Will Aftermarket Parts Installed Affect My Factory Warranty? - K8 Stinger Store
As you pointed out in your article, the Magnuson-Moss Warranty Act does prevent the dealer/manufacturer from blanket refusal of warranty because the car owner installed aftermarket part(s). However, that ONLY holds true if the dealer/manufacturer fail to demonstrate/articulate a plausible causality between the modified part(s) and the warranty claim.
If you bring your car for a warranty claim on a blown turbo charger. The dealer service sees that you have installed a device that is designed specifically to increase turbo boost pressure beyond stock mapping, they have every right to deny warranty. The increased boost pressure, which absolutely could cause higher-than-normal turbo charger RPM and/or higher-than-normal load/stress on the turbo charger - both mechanical and thermal - which in turn could cause premature turbo charger failure, beyond reasonable and customary expectation. Plausible causality is clear and present.
Now... if they try to blame your delaminated touchscreen on your JB4, that is a different story. That, they don't have much of a leg to stand on.
