New Coils!
jinthadell
Austin, TX.
Just ordered new HL Mando coils from Rock Auto on Tuesday, got them in this afternoon. Just finished installing them and car purrs like it should. Was getting a lil hiccup under heavy throttle so I knew it was time. Already had HKS plugs, so figured with 104k miles, it was time to swap them coils out. So the boxes showed up with 3 LH and 3 RH coils, or so they were marked. I actually received 2 LH and 4 RH coils. You can use a RH coil on the LH bank if you use it at the LF cylinder, closest to the headlight. I saw 4 & 2 and was like, “gotta get them in!” Ain’t hurting nothing! $300 w shipping and yes they are the newer/upgraded units.
Were your actually marked "Mando"? I ordered the same from Rock and mine came in the Mando packaging but there's no manufacturer marked on the coil at all, in fact, it looks like the part # was scrubbed off.
2 were clearly marked HL Mando, 3 had marker covering the lettering and 1 had a white dot like the LH coils come from factory.
