HanStinger
- Aug 13, 2020
2020 Stinger 2L GT-Line
I had a check engine light come on and the car couldn't get to highway speed. Friend with scanner read out the code that said the two throttle position sensors were not agreeing. Restarted the car and it drove better so dropped it off at the dealer. Dealer saw code but thinks it is my use of the parking brake that caused the problem. Said it was unnecessary to use and I stretched the cable. The cable is touching something that interferes with the throttle. (Owner's manual says in yellow box to always use the parking brake). Anyway, they could not replicate the loss of power I experienced -- so returned the car with no charge to me.
But they also did two recalls while it was in. The fuel pump recall (NHTSA 23V634) letter says the problem causes "loss of drive power". The Emission recall is not mandated by NHTSA and has no number -- but it says that the dealer will update the ECM software to improve emissions.
Got the car back and it doesn't seem as responsive as before. I'm trying to figure if this is still the throttle position problem or did the recalls reduce the power?
In my thinking, improved emissions would translate into a loss of acceleration (kind of like VW Diesel Gate). To rule that out, did anyone do the emissions recall and get a car back that didn't feel as sporty?
Likewise, the fuel pump recall includes an ECM flash. If they dial back the action of the fuel pump, that would also cause what I am feeling. Did anyone notice a change in their car after the fuel pump recall?
A third alternative is that they disconnected the battery and the car is re-learning. I noticed the annoying ignition start / stop feature wasn't working on the way home. It just gave me an "A" inside a yellow circle on the dash. Looking into the manual it says something about the start/stop system needing some hours to recalibrate the battery sensor before allowing the start / stop feature to work. Maybe it will drive better tomorrow.
A lot to chew on.
A lot to chew on.
