xHawaiiToast
- Oct 4, 2024
Hey guys, I just created my account and I'm completely new to this forum-world, so please be easy on me. I already posted this question on Reddit and got some pretty harsh comments, even though I just want to find the problem and maybe help other Stinger drivers in the process.
So now to the issue: It started raining a lot in my area a few days ago and my Stinger is acting up like crazy in these conditions.
Almost every time I turn the steering wheel and give a lil bit of gas to take a turn, I can feel some tires spinning/slipping or the AWD-System trying to balance something. I don't know what happens exactly, but something sends clearly audible and feelable vibrations/shocks through the car. My guess is, that it's either one or more spinning/slipping tires, some clutch packs inside the transfer case engaging/releasing or other parts of the AWD-System or the brakes being applied and released a few times in quick succession (Torque Vectoring or something like that).
It feels like an issue with the AWD-System. It's like in a video I found, that shows the same problem on a Jaguar XE-R. I guess many describe it as AWD scrubning/skidding/slipping/whatever.
The Video is called: 2017 Jaguar XE-R Sport 35T AWD scrubbing.
A few days ago, when I drove off my driveway and the rain was pouring like crazy, I had my steering wheel turned in almost all the way to the right and accelerated a little from a standstill. The whole car just shaked (same as described above, but stronger/more/whatever) and didn't move at all. As if every tire was slipping or something like that. I let off the gas pedal, reduced the steering angle and drove off with even less gas than before.
Half an hour ago I was driving to get some food and basically everytime I took a turn or steered to drive left/right while pressing the gas pedal just a lil bit (as described above), I felt the same thing again and again. I had to drive around corners and stuff like a grandma to avoid this issue, but even then it happened some times.
Tbf I don't feel safe at all driving the Stinger in the rain with that issue because I don't want to damage anything and I'm scared af because I don't want to loose control or something like that. It's just ridiculous. I only had one car, a Mercedes C280 W204 RWD, before I got the Stinger and I never had any issues like that. I thought getting a AWD car will be so much better, but now I don't even wanna drive it anymore!
A lil bit of background information:
- My Stinger is a german version and is completely stock.
- The issue only happens when accelerating ( even if I just press the gas pedal ever so slightly) from a standstill and/or at low speeds, below 50 km/h.
- Issue happened at around 10°C - 14°C in heavy or mild rain.
- Issue happens also at much higher temperatures and when it's dry, but it's way less pronounced and happens way less often.
- My front tires are worn a bit more than the rear tires. I don't know why or if that's normal. I bought the car with ~29.000 km and now it has ~31.000 km, so I only drove it for ~ 2.000 km.
- I still have the OE tires installed ( Michelin Pilot Sport 4s 225/40R19 front and 255/35R19 rear)
- The left front tire is worn a bit more than the right one (Rim on the right side was refurbished due to some minor damage/scratches and they put a new tire on it) -> Could this alone lead to the issue?
I made some pictures of my front tires, but I can't post links or pictures, since I'm new... So yeah idk how to show them to you...
I apologize for such a long post. I'm just bad at summarizing and want to give you guys all the information you need to form an opinion. I hope you can help, because I'm just clueless rn...
I've read that this issue was discussed on this thread a few times in some other unrelated thread. I've read through 20 pages on this technical discussion thread that includes the drive train, but I didn't find any posts about this issue. So I apologize for starting a new one if there really are any others, but I really couldn't find anything. There's not even a search function on this website and I didn't find anything through google either...
