Krudelydunn
- Sep 8, 2024
Hey all, I’ve seen similar threads on here about this issue but have tried the fix mentioned there without any success. I just purchased a used 2018 GT2 which had an open recall for the oil feed line. During the purchasing process the dealer serviced the recall and during my pickup I heard a swooshing water sound when I took off. I assumed it was maybe my water bottle? Hours later I kept researching and found others facing the same issue after their recall had been serviced.
Most posts pointed to air in the coolant lines / engine as the culprit. This sounds like it comes from a failure to burp the coolant lines correctly after refilling the engine coolant after the recall.
I had a pretty bad experience with my dealer during this purchase and without getting into too much detail I’d prefer to avoid involving them in this fix if possible.
I manually attempted to burp the engine using a funnel and massaging the coolant lines while running the vehicle. I noticed a lot of air bubbles during this process and my heat started working again. However, the noise persisted during my next cold start.
The next day I decided to perform a full coolant flush, and used a vacuum refill tool to create a vacuum after draining all the coolant. The vacuum held solid for a few minutes and I then preformed the refill using that tool. I’d imagine this prevented any air from entering the system during the refill (so I hope).
Hours later I started the car and sure enough I hear that swooshing water sounds around the glove box area again.
Looking for any advice y’all might have around this issue. Have I just not driven the car enough since the flush? Do I need to re-flush the coolant until the issue stops?
Thanks all. Love the car so far but this is pretty unsettling.
