Snicklefritz
Sustaining Member +
- Nov 28, 2022
You did it again, the thorough work/joy of an enthusiast posting in-depth responses. Thanks, again.When I first got the Whiteline bars, I did drill/tap the brackets to receive Zerk fittings. Also drilled the bushings to let the grease pass through. However, I found that while the zerk fitting worked great, it was next to impossible to pump the grease into the tight gap between the bushing and the bar.
So, I later changed them out with greasable bracket and fitting from Energy Suspension and Prothane. These not only have the Zerk fittings, the bushings also have grooves molded into them to allow grease to flow. These work much much better. IMO, all aftermarket anti-roll bars should come with these.
