JSolo
2500 Posts Club!
I believe it's the 0107 cap.. same one that fits nissans. Will be doing my first bleed this fall.
That is correct. This is the one i got off amazon Amazon.com worked greatI believe it's the 0107 cap.. same one that fits nissans. Will be doing my first bleed this fall.
Did you use the thick or thin rubber gasket?That is correct. This is the one i got off amazon Amazon.com worked great
Used the thinnest oring. After 4 years/17K mi, was hard to tell new fluid from old fluid.Did you use the thick or thin rubber gasket?
