Aftermarket Wheels
What is Your favorite Wheel?
  • Total voters
    235
245/35/20 front 0 camber.
285/30/20 rear 1 1/6 camber car tracks perfectly straight getting on it or just cornering or tracking, no mods to fender wheels. Was on lowering springs. Now I'm on coilovers, ground to top of fender wheels 26 inches all the way around I might go down another half inch in the front, no rubbing 32 offset front 45 rear
So do you think you would have rubbing without the camber of 1 1/6 in certain driving situations? Such as in a sharp curve at good speed and hitting a dip or pothole?
Even my setup did that, once, and after one time I take that curve less speedy. I have the OEM 255 tire in the rear on a 9.5" wide 19" wheel with +39, and a dip in the middle of the turn made the RR, outside, tire smack into the wheel well. So, your question is always going to be answered "yes", it just takes the right conditions to force the tire into the fender.
Yes without the camber but this stance also allows for aggressive driving
20x9 +33 and 20x10.5 +40 lowered on Eibachs for a few more weeks until BC Racing coilovers show up. Yes, the wheels are two different designs. But the car doesn't know any different. Same offset, same weight, you just don't see both sides of the car at the same time so why not...stinger 2.webpstinger 1.webp
Gonna jump in here, Rohana RF2, 20X11 ET52, 295/30 MPS4S, 20X9 ET32(3MM spacer), 255/35 Kumho PS91.
I’m looking at some rear wheels 20x11 ET56. The extra 4mm would bring them inside the fender more but do you think these would hit anything on the inside (suspension)? Tires on them now are 315/35/20
20x9 +33 and 20x10.5 +40 lowered on Eibachs for a few more weeks until BC Racing coilovers show up. Yes, the wheels are two different designs. But the car doesn't know any different. Same offset, same weight, you just don't see both sides of the car at the same time so why not...View attachment 85196View attachment 85195
ha nice setup
I'm looking to swap my wheels with AB-52 from ARK. Anyone know what offset and width to pick? I was thinking 19x9+30 front and 19x10+45 rear. They also have other sizes in the picture.
Cool.
Sizes?
Front: 19x8.5 / 5x114.3 / +30mm / CB76.10
Rear: 19x8.5 / 5x114.3 / +40mm / CB76.10
Front Tires: 235/40ZR-19 Michelin Pilot Sport All Season
Rear Tires: 255/35ZR-19 Michelin Pilot Sport All Season
Lowered on H&R Springs
Yes, that would work just fine. The whole point of doing a square setup is so you can rotate the wheels front to back, so you need the same offset front and rear.
I am wanting to do a square set up as well and have 19x8.5 40ET. Will this work as worried about the front.
That is exactly what I run on the front. Obviously it would work in the back, but a spacer might make it more pleasing to the eye to more closely match the front almost flush look. My rear offset is 39 on a 9.5" rim. I run OEM staggered tire sizes.
Check out our customer @thisguystinger who just shared installed photos of the newly released Avant Garde M570R in 20x9/10.5!
Thanks for confirming
Is there an offset that would work for a 19 x 9.5 in the front…or is that too much to stuff in there?
Too much Ima thinking, from what I've read on here. 8.5 in front is the widest. I've read of that quite a few times. Even a 9" I have not encountered on here that I recall. Now, watch, somebody will chime in and say "I run 9s in front, offset 22, 265 tire and it's just fine".
20x9 +33 with 245/35/20 up front
20x10.5 +40 with 285/30/20 in the back. No issues
I asked because I’d like to run square with 4 identical wheels to enable proper rotation.
With no camber control, I’m eating up the outsides of the front tires and can’t share the love axle-to-axle and cross.
Now I just need to confirm 20x9 +33 will work in the rear.
Yeah, shouldn't be an issue at all in the rear. It actually is 26mm further away from anything on the inside compar d to the 10.5 inch wheel. And 12mm less poke than the 10.5 so no problem.
