Volfy
1000 Posts Club!
Actually, even the RPF1 18x8.5 ET40 cleared my Riaction coilover, although just barely. Depending on the tire mounted on the wheel, this might be okay. 225 is probably okay. 245 or 255 will have problem. Also, a lot of tires have a protector band that sticks farther out past the rim, and so that can cause it to rub against the coilover. I ran into that problem with Dunlop SportMaxx GT.I saw an old post of yours "We run 18x8.5 ET38 Enkei TFR with 255/40R18 and they bolt right on no problem. Clearance to the strut was tight, with only a few mm's gap, but they do clear." so that looks like the limit for inset, according to WillTheyFit.com is "10.4mm closer to the suspension strut." vs the factory 225s.
We no longer run stock struts, but I would imagine the clearances are similar.
So yeah, you can definitely figure that as the tightest you can possibly get away with.
Nope. An ET15 wheel with 10mm makes it +5mm effective offset.So taking the ET15 offset +10mm, would a 18x9.5 ET25 rim work? There's no more room to move closer to the strut, but that's still 28.1mm of poke vs factory. And if that's too much, then you just can't fit a 9.5" rim up front without crossing the scrub centerline, right?
