Antigravity batteries.
Hmm, not only this, but oftentimes Li+ batteries are half to 1/3 the size of the battery it replaces, do we know the "footprint"?
L x W x H
  • H6 - 278 x 175 x 190 mm
  • H7 - 315 x 175 x 190 mm
  • H8 - 355 x 175 x 190 mm
  • H9 - 395 x 175 x 190 mm
Update, battery arrived. Will install later this week, some pics of the battery and screen shots of the App while connected to the battery.
Casing quality and grab handle are good. Weight is not much more than the Antigravity (6.5kg vs 8.2kg) considering the additional 20Ah.
Nice. Shows individual cell voltages. Is that their own app, with a cable plugged into a port on the battery?
I guess, they sent me the link to the app. Its connected via bluetooth
Surely it's wireless and self contained
You have a link to this product?
Installed the battery and all went well. The App is quite interesting, you get to see how hot the battery gets and shows you how the battery via the BMS cycling between Charging-Standby-Discharging.
Attached is their leaflet, has all their contacts. My battery is not listed there, its an L2-400 but with 60Ah.
Had to do some traveling and the car was not started for three weeks, was a good opportunity to see how the battery performs without a trickle charger. Came back accessed the battery via the app before starting it and noticed it lost very little power.
nice my PowerTex i think is toast.. i took it for a drive and stopped and the gas station and upon powering off the car just went black…
I had the same issue. It would throw a ton of errors. I put in a new AGM one that so far has been robust as hell.
was the lithium worth a lot in the black market???
