Daniel @ K8 Stinger Store
1000 Posts Club!
- Oct 24, 2017
Is excited to present to the Stinger forums:
STOLZ Big Brake Kit
(BUY NOW)
Description:
With over 30 years of experience in aftermarket automotive manufacturing, Stolz was established in 2003 to focus on high-quality brake component development
Addressing common issues found in the stock Stinger brake system, this big brake kit will significantly enhance your driving experience and stopping power
Stolz Big Brake Kits feature a monoblock lightweight 6-piston caliper, available in four color options: RED, SILVER, BLACK, and YELLOW
This kit includes patented 2-piece drilled floating rotors designed for excellent heat dissipation and reduced weight
High-quality reinforced brake hoses are included to prevent vapor locking and corrosion
Additionally, this kit comes with Stolz’s high-performance signature sport ceramic brake pads, matched explicitly for the Stinger
Stolz brake rotors undergo an extensive manufacturing process, including heat treatment up to 800°C (1472°F), ensuring they can withstand spirited driving
This Stolz Big Brake Kit provides shorter stopping distances, improved brake modulation, a firmer brake pedal feel, and less brake fade compared to the factory Brembo's
Specifications:
Brake Pads (4)
Rear Calipers (2)
Front Calipers (2)
2pc Lightweight Rotors (4)
All hardware included
Material: 1800T Forged Aluminum Alloy
Pistons: 6 total: (2x40mm, 2x36mm, 2x36mm)
1-year warranty through the manufacturer
Vehicle Applications:
2017-2020 G70 (All models)
*This kit is designed to replace the factory braking system on your Kia Stinger or G70,
and is a 1:1 replacement, compatible with all of the different trim levels for the models shown above
THANK YOU FOR LOOKING!
