Hi all. I replaced all four rotors and pads recently and all went well except for a grinding noise coming from the rear right. Braking doesn't change it but there is a slight change in noise going around corners. I suspect its the parking brake shoes inside. Both rotors and pads on the rear are identical. I removed the rotor and everything seems fine and I even rotated the adjustment cylinder to draw the shoes inwards away from the rotor but it made minimal difference. Anyone had this issue? It's not the brake shield as I can see all the way around and it never gets close to the rotor. Nothing else near it either.
I'd like to be able to rotate the rotor with the wheel off but I can't seem to disable the parking brake. I've put it in neutral and audibly heard the brake release as usual, but when I try and rotate the rotor it moves an inch or so then locks. Is there anything else I should be doing to fully release it? I've only got one wheel up.
