djerickd
1000 Posts Club!
Are you still daily-ing the Antigravity? Still no issues thru summer?No. Year later, everything is good.
The car lovers social network
Automotive components
Automotive Hot or Not
Explore Pet Insurance!
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
The Food Order Method
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Still driving, without complaints. Since it's in the back, I don't think cold or hot weather is an issue.Are you still daily-ing the Antigravity? Still no issues thru summer?
Closing on 3 years now, no issues so far. I put it on the trickle charger if I know I wont drive the car for a week or more.
To be honest, it's little disappointing. I would've expected more than 5 years out of it. Will see how long I can get out of mine. I drive it every day. Hopefully that prolongs its life. Which one are you gonna replace it with?FYI, the Antigravity battery finally died today. I purchased it in April 2019, so exactly five years. I left it without using the trickle for a couple of weeks, the jump start mode didn't help, I think if I put it on the trickle would have been ok for another year or so.
me too, i was expecting at least 7. Not sure what im going with, need to research and see whats good in the market.To be honest, it's little disappointing. I would've expected more than 5 years out of it. Will see how long I can get out of mine. I drive it every day. Hopefully that prolongs its life. Which one are you gonna replace it with?
I don't have enough knowledge about batteries to give any suggestions. Are you thinking about another lithium one, or regular?me too, i was expecting at least 7. Not sure what im going with, need to research and see whats good in the market.
Any suggestions?
Hate to say this, but using the trickle charger likely caused its early demise. LiFeSO4, like most batt types based on lithium chemistry, don't like being fully charged. At or near 100% charged state encourages lithium dendrites to grow. With enough of them, the cell shorts out and is rendered ineffective. Lots of online resources that describe in detail. Some LiFeSO4 batt mfrs specifically advise against long term storage with a trickle charged attached.FYI, the Antigravity battery finally died today. I purchased it in April 2019, so exactly five years. I left it without using the trickle for a couple of weeks, the jump start mode didn't help, I think if I put it on the trickle would have been ok for another year or so.
Do any lithium car batteries include an externally accessible balance port?If your LiFeSO4 has a balancing port, a cell balancer is also an excellent idea.
Shorai does, which is why I run them on my motorcycles.Do any lithium car batteries include an externally accessible balance port?
Balancing is only required periodically. Most of time time, there is no problem running the battery on alternator, just like any other batt type. Also, balancing is more accurately done by selective discharging with rather small discharge current, instead of selective charging with full inrush current from the alternator output voltage. Realistically, trying to bullhead balance the cells while the car (or motorcycle) is in operation is fraught with danger. Done wrong, the attempt to balance can do more harm than good.Don't they all have internal BMS controllers, allowing them to be compatible with a vehicle alternator?
Does shorai make any automotive batteries? I thought they only did power sport batteries.Shorai does, which is why I run them on my motorcycles.
For this reason, I've always been a bit leery of those claims of built-in circuitry able to do balancing on the fly. Maybe they are pretty darn smart and can do that effectively and safely. I just prefer to do it externally, with equipment I know exactly how it works. Until enough evidence suggest internal balancing does indeed work.
Not that I know of.Does shorai make any automotive batteries? I thought they only did power sport batteries.
Still never seen an automotive battery with externally accessible balance ports.
I run Shorai batts in all my motorcycles, and Shorai has its own charge/balancer than has a "storage mode" that essentially drains the batt down to around 60%(?), for this exact reason.
Having said that, no battery types like being fully discharged either, including lithiums. So if you are putting the car away for more than a few weeks, it's best to pull the battery negative cable and disconnect it. This way, you don't need to worry about small parasitic draws eventually draining your battery. But if is less than a couple of weeks, I wouldn't worry about charging the batt, unless you have aftermarket devices (like 24/7 dash cameras) attached that draws current constantly when car is off.
What I would suggest is to get a charger that is specifically designed for LiFeSO4. Use it to charge the batt when needed (like coming out of a month-long storage), but disconnect it as soon as charging is complete. If your LiFeSO4 has a balancing port, a cell balancer is also an excellent idea. I've already got one for my RC cars, so I just use that.
Wouldn't it have been better for the battery longevity, to do nothing?Been using an Optimate TM-471 which is a lithium LiFePO4 specific charger from the battery supplier themselves. Only use it when the car is parked for over two weeks.
Perhaps monitor the voltage periodically, and only charge if the voltage went below ~30%SoC?, which I assume would take several months of storage before self discharge + parasitic draw would deplete the SoC to ~30% or some safe #)
Any warranty?No idea to be honest, was following Antigravity instructions.
For the price, I would expect a MUCH longer warranty.latest technology for the safest, longest life cycle possible.
I won't have a problem buying another one, if I can get 9 years out of it. Mine is little over 2 years old, so will see.For the price, I would expect a MUCH longer warranty.
