Sunroof leaking
Rjt187
my 2019 stinger seems to be leaking from the sunroof, filling my cup holders with water. Anyone experience this, it’s probably a clogged drain I know, but didn’t find anything on this cars drains specifically. Thanks in advance.
Some files attached
I'm having the same issue with my 2019. I curse kia for not making the sunroof optional on the GTS. Unfortunately none of the sunroof documentation in the repair manual mention drain holes unless I missed it. I'm going to try duct tape to at least determine if it is the piece ahead of the sunroof that is leaking. I only get dripping in the cabin when I'm at speed while it's raining. No issues (knock on wood) while I'm parked during a session of rain. With other problems I'm having, this will be my last Kia.
I was also curious about this maintenance wise. Did you guys find out, or does anyone know if there’s a drain we need to clean every so often from debris? @ghodge @D.J. @Rjt187
I have never done any sort of sunroof drain cleaning.
No issues, no leaks.
Ever find out what the problem was? My headliner gets wet when I go through a carwash especially in the winter months. We got heavy wet snow today and my cupholders were full of water and the headliner pretty wet. Assuming its a seal issue or possibly clogged drains but can't find anything.
